Thread: Battery worries
Old 04-26-2011, 02:17 PM   #2
442nd986s
Originally Posted by Bobitupa
Hi jcb cheers for reply again bare with me is amp same as cca lol just heard both mentioned would u advise changing to 700 also is it easy to check what u said or is it a garage job and if all can handle it would it affect performance like I seem to be getting gunna give it a run again tomos to see if still the same cheers pal
In regards to AMPS:
It's best to have more than THE NEEDED amps. In any circuit, if you reduce the amps available at the power source you will put a strain on the battery/power source. So if anything......go higher on CA.
442nd986s is offline   Reply With Quote
