Old 04-26-2011, 12:23 PM   #13
jhandy
It is my understanding that chain pads are brown-tan, and the tension rails are black plastic. however, look at the porsche gasket set for the 986. There appears to be a lot of green o-rings in the bag.
http://www.****************************************.com/Part-Number/Engine-Gasket-Set-NOTE--Does-not-include-head-gaskets-or-valve-stem-seals-NOTE--Also-use--(1)-000-043-204-35-Loctite-5900-__98610090500_O-prd-E_6BB4EABD.aspx
http://www.eurocarparts.com/ecp/c/Porsche_911_3.6_2001/p/Car-Parts/Engine-Parts/engine-parts1/car-gasket-seals/?361330085&1&88a8a23cab73e482554f05e3940ea876b516ffca&ENGS
surely someone like Jake who has torn these motors down should be able to give us a top 5 list of green plastic parts in the motor.
2002 S
jhandy is offline   Reply With Quote
