Old 04-25-2011, 05:47 PM   #1
Overdrive
Opposed to Subie Burble
Overdrive's Avatar
Originally Posted by gschotland
If your top's in otherwise good shape (from what little your photo shows it appears to be) consider replacing the rear window only. This is far less costly than replacing the entire top. Lots of posts on this topic. Do a search.
Thanks, gschotland. Do you know if people have put glass into their original tops that came with plastic? The top does have some wear at some points, you can kind of make some out in the picture above where there's some darkness in the top (bottom left quadrant of the image). These areas where the top folds show some very light abrasion to the material, but nothing that would warrant replacement. I just figured unless there's a way to put in a heated glass window I'd end up having to go for a new top with one in it. I don't really want to replace it with plastic again, as I'm still suspicious that someone was a jerk and cut it.
-O/D
IMSR + RMS
Robbins glass window top
