Old 04-18-2011, 06:06 PM   #2
Mike_Yi
If you correctly use a vacuum filling system, there is absolutely no need to open the bleeder afterwards; in fact, you are creating an opportunity for air to get back in to an otherwise air-free system at that point.
Not really. When you remove the bleeder, air gets in the system. I already had to add coolant at that point, before even firing it up. I did use the system exactly as the directions indicated.
Mike_Yi is offline   Reply With Quote
