Old 04-18-2011, 12:40 PM   #5
J Tinsby
J Tinsby's Avatar
Here you go:
Originally Posted by dirkdiggler
Cool, thanks....that makes me eager to try them out!
anyone know what the Ohm impedance will be at the amp with qty 4 speakers that are 6ohm each??
I can't tell you without seeing the wiring to determine if they are wired in parallel or series. One way gives you less resistance the other way will double it.
Here is a link with photos to show you how to connect them either way. It would be helpful to know what the amp is expecting to "see" at the speaker connections.
http://www.bcae1.com/spkrmlti.htm
Good luck!
"Never force it.... get a BIGGER hammer!"
J Tinsby is offline   Reply With Quote
