Old 04-16-2011, 11:37 AM   #1
mikefocke
Parts
10 quarts of your favorite oil
oil drain pan allowing 12 quarts
Rags
filter (WIX/NAPA makes a nice one #57211) with O-ring
crush ring 900.123.106.30
drain plug is reused after cleaning it unless you want to buy a LN magnetic drain plug
filter wrench 74/76 mm
8mm allen wrench (I'll confess, I don't torque it. I tighten it enough to compress against the crush ring without stripping the threads in the pan as that can get very expensive)
Instructions here http://www.pedrosgarage.com/Site_3/Change_the_Oil_%26_Filter.html
