99 Boxster 130,000 miles, 70k by me since 9/05.
In no particular order...
VarioCam solenoid valve
MAF sensor
O2 sensors- x2
AOS
Coil Pack
Alternator
Starter
Water Pump- with snapped bolt
EVAP purge valve
Transmission torx bolts- no side to side shifter movement
Clutch- done with above
RMS- done with above
IMS hardware upgrade- done with above
Clutch slave cylinder- done with above
Ignition switch
Handbrake switch
Convertible latch switch
Window regulator- both doors
Horn frame
Convertible top
Serpentine belt
Battery
Fuel level gauge not reading 100%
Coolant tank cap- x2
ABS wheel speed sensor- x2
Lower control arms- x3
Drop links- x6
Tie rod end- x2
Wheel bearings x2 front including 8 Timeserts
Emergency brake shoes and misc parts
Seat heater switch
Wheel well liner- both sides
Shift lever ball joint snapped off
Motor mount- x2
But only towed 3 times!
