I had the similar amount of leak on my car last year. I freaked out because of the IMS bearing failure discussion in here. I sent my car to my porsche mechanic get it fixed immediately (cluth, IMS and RMS). When we had it apart, we found out that the leak was from RMS. Hopefully your is from RMS too.
Only if I knew that it was from RMS, I would have waited until my clutch is completely gone before I do something (I did not check my oil filter for metal particles).
My suggestion is try to look for metal debris in you oil filter. If you have no metal particles, I guess it might be safe to assume that it is the RMS that leaks (but check it every time you change your oil).
