Old 03-31-2011, 12:15 PM   #4
Gilles
Originally Posted by Flavor 987S
Not sealed. Just low maintenance. You have to "cut or break" through the black label on top, to access the 6-8 plastic screw caps. I forget how many cells there are. You can see the level on the sides, or look down the open hole. You'd be surprised how much distilled water these can take to top off when low!
Just peel the label at one of the corners to expose the six plugs, inside you will see a "small metal strip" that serves as a lever gauge, just cover the small 'leg' of the metal piece with distilled water. sounds confusing but it's pretty obvious once you look inside, just be careful and wear eye protection because you may get some splash back from the cell
