Originally Posted by Kerry
noob question......isn't the OEM battery on my '07 sealed? How do I check the electrolyte level and top off with distilled water if necessary? Thanks!
Not sealed. Just low maintenance. You have to "cut or break" through the black label on top, to access the 6-8 plastic screw caps. I forget how many cells there are. You can see the level on the sides, or look down the open hole. You'd be surprised how much distilled water these can take to top off when low!
