Old 03-29-2011, 04:49 AM   #10
mts
Originally Posted by chamilun
http://986forum.com/forums/showthread.php?t=24656&highlight=oil+change+frequency
Not sure why you answered for them, but I have searched, and haven't found any evidence that frequent oil changes change anything. Not saying it doesn't, but facts are important
They've posted about it a bunch, not sure they want to keep answering the same questions over and over again because people are too lazy to do a little research/reading.
From Charles' website:
"What can be done to prevent an IMS failure?
There is no quick or easy fix. Like with many aircooled engines, many get torn down and rebuild BEFORE an engine failure so that engines can get upgraded. Short of a pre-emptive rebuild, the best preventative measures that can be taken are to be religious with your maintenance schedule. But keep reading, there's more that you can do.
What can be done is to change your oil more often. We recommend oil changes for the M96 and later engines (as we do for air-cooled engines) every 5,000 miles or 6 months.
If you track your car, you should change the oil after every race weekend or every other event at the bare minimum and should also consider used oil analysis to monitor the health of your engine.
Use a higher viscosity motor oil. There are several Porsche approved oils that are 5w40, rather than Mobil 1 0w40. Use of an oil that isn't API SM-rated with more Zn and P or an oil with moly extreme pressure anti-wear additives may improve engine life. Castrol Syntec 5w40 is an API SL rated oil that carries Porsche approval and is an excellent choice, and easy to get locally. Motul 8100 5w40 is another excellent Porsche approved lubricant. "
2004 550 SE #1081 of 1953 (sold)
1997 911 Targa (sold)
mts is offline   Reply With Quote
