Old 03-28-2011, 06:11 PM   #1
Jake D
Originally Posted by olly986
i am very interested, mine is very stiff at time and i have to push at the front of handle to be able to open the trunk, i hope that it is not the cable worsening the other ressort is to use the key only to open the trunk it will be cheaper you should be able to buy batteries for the next.....50 years :dance:
Go pick up some Dry Slide and lube the cables. My front cable was stiff. Lubed it up and its smooth as can be now. Most of the time you can find that stuff at motorcycle shops. We use the stuff to lube throttle cables,clutch cables on bikes.
http://i67.photobucket.com/albums/h3...IMAG0137-1.jpg
00 S Triple Black- Smoked lights, Tinted windows, Stainless exhaust, IwireP ipod cable, desnorkled, painted bumperettes
Jake D is offline   Reply With Quote
