Thread
Does the Durametric display "pending" codes?
03-28-2011, 08:49 AM
7
paulv
The 986 models typically have a 0.9 to 1.1 V reading at the MAF sensor with the ignition on, engine off. With the engine at idle, the voltage reading should be around 1.4V. IF you're not seeing this, the sensor is most likely bad.
Regards,
paul...
paulv
Find More Posts by paulv
