I also have the Durametric system and yes it will show fault codes that may not trigger your CEL. I recently cleared two alarms from my 2001 Boxster (P1128 and P1130) that did not trigger my CEL. A possible cause for these two trouble codes is a dirty MAF sensor, so I cleaned the MAF sensor (using MAF sensor cleaner and Q-Tip) then cleared the alarms using the Durametric system. I will check for these alarms later in the week, hopefully cleaning the MAF sensor solved my problem. I recommend using your Durametric tool and check your Porsche's systems occasionally... Stay on top of any minor issues before they become major trouble later.
