Old 08-16-2005, 06:50 AM   #5
frankkerfoot
[QUOTE=Brucelee]The VIN number does not tell you when your box was built. It will tell you what country it was assembled in and the sequence of build order.
If you search on VIN number here, you should be able to find my post on what the VIN number actually tells you.
I got my 2006 Boxster S about 2 weeks ago (ordered in May). The VIN number has an S as the 11th digit, indicating a Stuttgart build, but the top of the window sticker says: "Final assembly point: Uusikaupunki Finland". Do they just use one flavor of window stickers, and the VIN number is the real key, or what?
Thanks in advance,
Frank
frankkerfoot is offline   Reply With Quote
