Old 03-18-2011, 04:51 PM   #4
gschotland
Both windows are fused on D1, so you probably have some other problem.
It's pretty easy to swap the window switches in the center console to troubleshoot. Connect the good switch to the questionable motor and if it works your then your original switch is likely bad (a pretty cheap fix); if it doesn't work, then it's likely the motor or the regulator. Connect the questionable switch to the good motor and if it doesn't work then the bad switch is confirmed; if it does work, then your other motor or regulator's likely got problems.
I've read the window motors are pretty reliable. The window regulators not so much. I replaced my '02S RH regulator last fall and just ordered the LH today. Replacement is not too terrible. There are a couple of links to good step-by-step instructions with pix. Do a search.
gschotland is offline   Reply With Quote
