Old 03-16-2011, 06:44 AM   #2
jcb986
jcb986's Avatar
If the whining appears after the engine warms it maybe the AOS. What happens is when the AOS starts to go bad it will suck air around the front crank shaft seal...that's how mine did. I would suggest removing the front engine cover behind the seat and listen for the noise then disconnect the belt and if the noise is still there around the crank the it's the AOS.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
