Old 03-13-2011, 01:48 PM   #13
Mike_Yi
On top of that, there really is no good reason to not drive the Boxster in the winter. The car handles snow better than most cars if you put winter tires on it. It's galvanized, so it doesn't really rust. The only precautions I would take would be to hit all of the exposed screws and bolts on the underside of the car (mostly the undertray bolts) with some Boeshield to keep them from rusting. Everything else is protected well. Then, in spring, remove the undertrays and rinse the underside thoroughly. The car is a blast in the snow. If it gets wrecked, it's not like it cannot be replaced. Drive it!
Mike_Yi is offline   Reply With Quote
