Old 02-25-2011, 10:34 AM   #10
J Tinsby
J Tinsby's Avatar
Pump
Originally Posted by Jake D
I read somewhere that the pump is cooled by the gas so its not good to drive it low on fuel because the pump can then run hot and cause it to have an earlier life. This true?
Thanks, Jake
Jake,
It's true. Fuel is carried through the pump and does keep it cool. However the most damage to the pump is done by running it DRY. This normally will make the pump seize. If it doesn't do that immediately it will score the inside of the pump shortening the life of it considerably.
Years back this was a common problem on VW's with the continuous injection systems. But is true for all electric pumps that use some sort of spinning impeller to move the fuel. Don't run it out of gas! An old Lucas style pump would be immune to this abuse...but you don't have one!
"Never force it.... get a BIGGER hammer!"
J Tinsby is offline   Reply With Quote
