Originally Posted by Frank M
Did you install the aux jack on the stock radio? if so can you share how you did it?
also are the red calipers covers or actual red cailpers?
thnx
FM
The cable that I bought was the BLAU-8 audio adapter from
www.discountcarstereo.com. On the end of the BLAU-8 you can get an AUX input or an iPod cable input connector. See
http://www.discountcarstereo.com/detail.aspx?ID=993
I installed the aux jack into the stock CDR-220 radio. Very easy. Pull the radio using the $3.99 radio tool and the aux cable plugs into the connector for the CD changer on the back of the radio. Then I ran it down the backside of the center console and drilled a small hole in the rear of the storage cubby. So my music player and cable are nice and safe from rolling around in the lower cubby.
Yes, the calipers are really painted red. I recently changed the front brakes rotors to the drilled type and they look really great (and perform really well too).
