Old 02-19-2011, 04:37 AM   #5
Flavor 987S
Originally Posted by stephen wilson
I assume you have PASM? I don't like the standard PSM when I'm trying to have fun on a nice warm day. It steps in WAY too early, cutting the throttle, and not allowing any "rotation". My next car I'll have to look into PASM, as it would be nice to still have a "safety net" vs. just turning it off like I do now. I'm looking forward to the drive home tonite!
PASM- Porsche Active Suspension Management (also makes the car 10mm lower than a non-PASM car).
PSM-Porsche Stability Management- standard on all 987's.
Keep in mind, when you turn "off" the PSM, it will turn back "on" under servere or emergency situations.
If your PSM is kicking in a lot, check simple things like tread wear and tire pressures. You can also do things to improve your "line" and be more smooth with throttle and steering inputs.
