Old 02-15-2011, 07:55 PM   #2
Hawkeye71
I pulled the bumper cover off and removed the brackets from the bumper that hold the humps. There pop riveted on so all you have to do is grind the rivets off. Then just cut a piece of plastic out to size and put it over the entire back section. Might make a cover out of carbon fiber latter on. Not sure yet. I do like the way it looks now.
It was black plastic so no need for paint.
If you want I could mail you the brackets I pulled off. You should be able to pop rivet them back on your bumper if you want to put the hump back on.
Hawkeye71 is offline   Reply With Quote
