Old 02-13-2011, 04:12 AM   #1
shlim8
I checked, the power steering fluid is at the "o" alphabet of the word "cold" on the dipstick when cold. Which is actually above the lower arrow mark. According to the manual the fluid level should be "below the arrow mark". I guess I can rule out low fluid.
I realize that the steering has a bit of free play... not sure if its normal or not... while driving even at high speeds, I can rock the steering wheel maybe a inch left and right, back and forth without the car reacting (with change of direction).
The vibration seems worse when steering is turned.
Bad tie rods or rack ??
shlim8 is offline   Reply With Quote
