Old 02-12-2011, 06:27 PM   #13
Jaxonalden
Jaxonalden's Avatar
At idle I don"t think you'll hear it, idle should be normal being it's a four valve set up. Remember, if it is a broken spring, the chances of dropping that valve increase significantly with greater RPM because it will float a whole lot sooner. You might want to pull the valve covers and do a look see first.
