Were you low on oil?
You might have had a weak lifter or hearing chain noise
All hard to tell without knowing what it sounded like.
Mike
					Originally Posted by Fluellen
				Update:
I drained the oil and filtered it through a washcloth. No foreign particles. No intermix. Removed the filter and cut it open - nothing. Looks exactly like the previous three filters I cut open.
Re-filled with Rotella 5W40 (same as before; last oil change 5 months / 1 Kmi ago) and started it. Smooth idle, no noises.
I haven't checked for noises above-idle yet (all engine covers are off, and the motor gets quite loud when you go >1500 rpm).
I guess I'll look at the spark plugs tomorrow, just in case.
Is it possible for a valve spring to be broken, and you can't hear it at idle?
				Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
