Old 02-10-2011, 06:34 AM   #1
deliriousga
deliriousga's Avatar
Thanks. I went ahead and ordered another one and will take everything apart again this weekend. I've never had to check if the release lever would move properly since it's all one pack in the 928. Didn't think about that since the Boxster puts it together when you put the transmission in.
Should I start the engine and let everything engage before I push on the clutch pedal for the first time? I'll check the levers and such, but it's odd to me that the release bearing is not attached to the pressure plate so this setup is unfamiliar.
Thanks for the help!
1966 Wife White/Brown Top
