Old 02-08-2011, 02:51 PM   #2
jhandy
There's a clunk or clatter from around the right rear strut mount, over bumps, rash.
It's been checked out by pros. Nothing visibly wrong. Suggestions?
lower rear track arm. You will only notice maybe a little oil leakage and dirt at the rubber seal where it bolts to the body.
Passenger window squeals like a murdered dolphin as it goes up its final six inches.
Lube? Align? Clean? Where?
remove door panel and lube the rails and gears. I used white lithium grease, worked fine for 5 yrs now.
2002 S
jhandy is offline   Reply With Quote
