Old 02-07-2011, 05:18 AM   #2
mgstu
Electrical expertise needed
Originally Posted by Burg Boxster
yep - that simple... carefully pull the "sail" panel up, then off and reverse the plug.
It is a common problem which occurs when one removes the door panel (to fix something or upgrade speakers etc.) and puts back in place in reverse w/o checking before closing everything back up.
Hi and thanks for the response,
can you please enlighten me regards the 'sail' panel, is this the door panel? Also, how will I identify the correct plug? Unless there is only one under the 'sail' panel.
Cheers
mgstu is offline   Reply With Quote
