Old 08-09-2005, 04:44 PM   #1
Killertraylor
Originally Posted by SD987
My understanding with the Litronics upgrades is that:
The self-adjusting mechanism incorporates ballast placed in a remote part of the car that makes it impossible to fully retrofit, is this not the case in the 986?
I'm assuming that the headlight washing functionality that is part of the litronics in the 987 is not part of the 986 package?
Not sure what you mean by "fully retrofit" but if you mean you don't have the auto leveling feature that the factory installed liltronics have, you are right. They still rotate up on high beam, but don't rotate up (for example) when you slam on the brakes and cause the nose to dive like the factory ones will do. I'm not sure about the washers - wouldn't want them even if I could get them, so I didn't investigate it.
Killertraylor is offline   Reply With Quote
