Originally Posted by Paulsingh
The problem I'm have is the roof is locked in a closed position. When I try the roof button, I don't get anything (I can't hear any transfer of power).l
Paul, do you mean the big button on the convertible itself, the one that lets you unlock it from the windshield, or do you mean the electronic switch to lower the roof?
I'm going to assume the switch to start the motor...
Check what Padro said first, if your brake is engaged and you 'release the roof lock' what happens?. I know there is a little switch like the cover of an old clothes washer that stops the spin cycle if you lift the top...only the reverse on the latch for the top of the convertible.
