Old 01-28-2011, 03:15 PM   #10
Steve Tinker
Steve Tinker's Avatar
Sam - bad luck with the fire, at least you caught it in time before they found you burnt to a crisp......
In regards to wrapping the headers, its a hell of a job because of the space, or lack of it...
I have found on my motorcycles and MX-5 (Miata to you Yankees ) that ceramic coating the headers internally and externally reduces heat by nearly 30% and is a permanant fix. There are quite a few companies in Australia that do it and I can recommend the heat reduction is significant and (according to the blurb) a slight power increase too.
You'll still have to tie your PS line out of the way though - the cooler the Pentosin fluid runs, the better for your PS pump.
2001 MV Agusta F4.
