Old 01-28-2011, 12:39 PM   #3
Maxodus
Originally Posted by Mike_Yi
Before you think about removing your alternator, spray the sleeve at the rear of the inboard bolt with PB Blaster a day ahead of time. Then do it again shortly (an hour or so) before you try to remove your alternator. I broke my alternator trying to get it out. While JB Weld fixed it, it was a PITA.
Also, be VERY careful if you remove your regulator. On two alternators with two screws each, I broke off 3 of the 4. They are tough to remove.
Thanks for the pointers regarding the regulator screws - i better watch out for them this weekend when i try to remove them!
2003 Boxster 2.7L 5 spd
Maxodus is offline   Reply With Quote
