Old 01-27-2011, 04:47 AM   #2
insite
that line goes from the pump down to a fitting underneath the car. since you were quick to turn the car off & the fire sounds like it went out, you may not be too bad off....
you'll need to replace the line & check for damage to your wiring harness. specifically, check the wires that go to the ignition coils. also check your brake booster line just to be sure. maybe post some photos when you get it up in the air.
i may have an extra PS line; i will check when i get home. if you need wiring harness segments, i have those as well.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
