Old 01-27-2011, 04:41 AM   #2
sparker
This sounds quite likely (power steering fluid line). If it does turn out to be the issue, do you think it will just be a matter of replacing the line, refill power steering fluid (repair any other burn damage) and be good to go.
The more I think about it, the more I think it has to be power steering. The steering did give a tiny heavy spot just before it went... The fluid on the ground also felt like that. Would also explain why it went as I turned a corner (High pressure into melted line)
Ok the cause is starting to become clear - now the repair, any suggestion?!
Sam
sparker is offline   Reply With Quote
