Originally Posted by tamarsha
The track day in April will only be my second DE. I do not plan on over driving the brakes... I hope.
Looking at my rear pads I am thinking that they could probably be replaced. My plan right now is to replace both the front and rear sets with an OEM / street performance pad. I will also do a brake flush and heck, while the wheels are off, add some GT3 brake ducts.
So, any recommendations on a set of pads? I was thinking Textar, Padgid Blue (4-2 or 5?), Hawk HPS, or EBC red stuff.
I like the idea of lower dust, but I do not want anything that will perform less than the OEM pads I have on there now. The car gets driven about 2 days a week now and even more in warmer weather so I don't want to lose my street drive-ability.
Honestly, if this is your second track day, stick with the OE Textar pads. They will be more than enough for a long time. They are great on the street, even in the hardest braking situations. When you get to the point where on the track you start feeling a long semi soft pedal when braking hard, then it's time to think about track pads. (That's not your fluid boiling, it's friction loss on the pad.)
Stay away from the Pagid Blues. In my opinion, they are junk. I was not at all satisfied with them. They bit only marginally better than the OEs, but made a lot of noise and wore out really fast.
Pagid Orange and Yellows are awesome, but they squeel like a stuck pig on the street (and on the track too).
For track use, you should flush at least once every 2 years. I recommend once a year for track use.
