Old 01-10-2011, 09:52 AM   #10
BYprodriver
BYprodriver's Avatar
Originally Posted by spongebob
I'm not worried about loosing any torque as the engine is equipped with only two cats in many countries including Germany. Probably the powergain wont be noticable either. The main goal is to shave off some weight from the rear engine mounts which hopefully will reduce the annoying vibrations at cruising speed.( I know that the mounting height of the mufflers alters the characteristics of the vibrations)
If sound and throttle response is improved its a great plus.
Usually the cheapest way to dampen vibration is to ADD weight!
