Old 01-01-2011, 06:09 PM   #4
Topless
Track rat
Topless's Avatar
Originally Posted by Byron in Atlanta
Hello all...I am in the process of installing my new/used engine after throwing the rod in August. I was thinking that I would reuse the water pump from my blown engine as it only had a couple of thousand miles on it. When I removed it, the impeller was chewed completely up. It seems that when the engine blew, metal pieces from the engine case, rods or pistons entered the water channels and destroyed the pump. Any suggestions on how to clean out the cooling system short of removing everything?
Yikes! Agreed that your woes are not over. Impeller grenade fragments have lodged themselves in every nook and cranny of your cooling system. Hard to say at this point whether it was chicken or egg (failed rod or failed impeller) that went first. Was your replacement water pump a factory Porsche part or aftermarket?
