Old 12-29-2010, 12:47 AM   #4
sasha055
Figured out what I was doing wrong.. I was trying to use ball joint on lower control arm not on track arm.. and it won't fit in there.
Next question: How do I remove eccentric bolt?
I read that "it can be a bugger to get out" well.. it is.
I can move it about 5mm and then it gets stuck.. also I read that you have to use a pry bar to releive the pressure .. How do I use it? where should I push the control arm? up/down/left/right?
How did you got the bolt out?
Any help is greatly appreciated.
Sasha
sasha055 is offline   Reply With Quote
