The VHT caliper paint or rotor paint does not need to be baked. I have painted my rotors with it and all you have to do is bed the pads properly and at the same time you will seal the paint. they get damn hot and cool off, damn hot then cool off. 45 hundred miles later there is NO rust on the rotors except where I did not paint. just make sure you go up the the threshold of the pad wear for best results (visually)
this way you do not have to waste your time with an oven.
