Old 12-21-2010, 07:09 AM   #1
J60SON
Originally Posted by Stroked & Blown
Does the breaking performance improve as you drive a bit?
I'm no expert, but it sounds like there is moisture in the brake fluid that is freezing. A fluid flush should fix this.
Not in this weather, only if the temperature outside warms up?
I would tend to agree that there may be moisture somewhere that is frezzing with the climate. I would have thought that if moisture got into the brake fluid it would tend to give a sponge effect on the brake pedal which it doesn't.
I will try a full flush when we get a spell over frezzing point.
Thank you for your advice
J60SON is offline   Reply With Quote
