Old 08-02-2005, 01:19 PM   #1
bigislandboxster
I'm not familiar with the rear speakers, as I do not have any and have not worked with them...The door speakers are supposed to be subwoofers/woofers and are only supposed to emit low frequencies, tho I don't know the cutoff.....Either the stock amp or the head unit probably has the low pass frequency for the doors built in and at a set point(Probably the head unit). As far as the door speakers wiring, the left door I believe is the green wires, and the right door the purple wires. If you check your head unit plug you should be able to see these easily.....The wires with the brown going thru them is the negative in case you didn't know
Lou
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
