Old 12-10-2010, 01:52 PM   #14
pothole
Originally Posted by yelojkt
The only time that you should heel-toe is when you are driving the car at it's full potential. Race car drivers and people who drive HSTs heel-toe because they wait until the last second to brake for a turn. They never coast. It is gas or brake. And when you are trying to get into a corner fast while braking and shifting you need an extra leg for the accelorator pedal to rev match. So you use your heel. This is an advanced driving technique and should not be used on the street, in most cases.
Nonsense. Heel and toe is a perfectly legitimate way to drive on the street. In fact, it's the only way to drive if you want to drive smoothly and in full control. You certainly don't need to be anywhere near the limit to do it or to benefit from it. Heel and toe is not actually about getting into corners fast, it's about matching road speed and engine speed. It also just happens to reduce wear on the clutch.
pothole is offline   Reply With Quote
