Old 12-10-2010, 09:00 AM   #10
yelojkt
The only time that you should heel-toe is when you are driving the car at it's full potential. Race car drivers and people who drive HSTs heel-toe because they wait until the last second to brake for a turn. They never coast. It is gas or brake. And when you are trying to get into a corner fast while braking and shifting you need an extra leg for the accelorator pedal to rev match. So you use your heel. This is an advanced driving technique and should not be used on the street, in most cases.
2000 New Beetle / in search of 03 986S triple black
Caractere kit seam sealed, Caractere rear wing, 1 3/4" drop on coilovers, 235/40/18 Kuhmo XS on 18x8 Millie Miglia Spider II's, H2sport spindles, H&R front Sway bar, O-bar rear torsion, VF Eng. motor mounts, G60 12# flywheel, Nuespeed P-flow intake, Forge DV, Samco IP, Custom K04 turbo and Upsolute chip, 4 bar fpr, TT 2 1/2" SS DP, 2 1/2" custom stainless exhaust no muffler, Peleguin LSD, B&M SS, Momo 14" wheel, R32 steering rack.
yelojkt is offline   Reply With Quote
