Old 12-08-2010, 06:11 AM   #4
eightsandaces
Originally Posted by panameras
Yeah I will be replacing the MAF either way. Just thought if I should also look at the AOS since I can see a bit of oil down there but it's not dripping or anything...
The 2nd and 3rd are the same pic (one with flash). The top pic was shot from the same position but with a wider angle so the viewer can see where exactly the oil is, in relation to the throttle body.
So the oil is at the lower connection for the AOS? The car does not seem to have more than expected smoke during start ups. Although it always had more smoke than other cars I own.
It's a characteristic of H6 or flat 6 engines, completely normal, I'd leave the AOS alone then and just replace the maf, see if that doesn't cure what ails ya..
eightsandaces is offline   Reply With Quote
