Old 12-08-2010, 06:01 AM   #3
panameras
Originally Posted by eightsandaces
OK if I understand correctly you are going to install a new MAF, which sounds like a good plan. The top pic looks like the J tube for the AOS, the bottom pic is the lower connection for the AOS it might be time to look at it too if the car smokes more than the expected start up puffs.
Yeah I will be replacing the MAF either way. Just thought if I should also look at the AOS since I can see a bit of oil down there but it's not dripping or anything...
The 2nd and 3rd are the same pic (one with flash). The top pic was shot from the same position but with a wider angle so the viewer can see where exactly the oil is, in relation to the throttle body.
So the oil is at the lower connection for the AOS? The car does not seem to have more than expected smoke during start ups. Although it always had more smoke than other cars I own.
panameras is offline   Reply With Quote
