Old 12-07-2010, 06:57 AM   #1
vipola
Originally Posted by jow
Hi,
thank you for the replies!
I had a look at the option code list for a Boxster. The link you provided gives 'strange' options for a Boxster.
The list I found gave me the correct codes (for example 411 as 18" Carrera Wheels or 571 Charcoal filter and so on) so I assume the list I found is correct.
anyway: I lifted the ashtray out and lifted the console which contains the switches.
I found two unused rather large connectors, one white and one black, each had six or seven cables attached to it.
Are these for the seat heating? That would be easy I then only need to buy the switches or don't I?
Regards,
jow
You most likely have the wirring in the car for the seat.. the question is: do you have heatable seat connected at the other end of that wire? :P
vipola is offline   Reply With Quote
