Old 12-07-2010, 12:33 AM   #1
eightsandaces
Originally Posted by BassMD
I removed the rubbery trim piece and what is revealed is a plastic collar around the switch, with a tab at 12 O'Clock. I tried pushing and pulling gently on the tab, and twisting, but nothing budged. Not wanting to break anything, I desisted. Advice?
OK because its 3am and I'm up (medical stuff) , I'll look it up.....
OK after you remove the trim and boot, this is from Bentley
1) Insert ignition key and turn to position one (ignition on) insert straightened paper clip into hole at top right of key slot, press clip into the hole as far as it will go, pull lock cylinder out of steering lock housing.
Reinstall is reverse of removal, place ignition lock in position one, (ignition on) then lock cylinder barrel pawl with paper clip..
good luck Mr. Bond
eightsandaces is offline   Reply With Quote
