Old 12-03-2010, 01:29 PM   #1
JTP
Originally Posted by Lobo1186
if they are like dark blackish brown and kinda clear and glassy even from what I understand that is a normal byproduct.
Changed the oil today and cut open the filter. 50k miles On engine and 5k since the last oil change.
I found little bits, 1-2mm in size, of hard brown glassy particles on the filter along with a few specks of bright red bits. No metal shavings but there was one piece of tan soft rubber, like a portion of a rubber diaphragm. Very soft and stretchy.
Are the brown pieces from the chain tensioners and is it "Normal" to find them on your filter? I probably had one or two pieces on every other pleat.
JTP is offline   Reply With Quote
