Old 07-30-2005, 03:32 PM   #1
RENNX
Question for you guys. I to was loosing coolant in my tank, but into the trunk nothing on the ground. I assumed it would be the same issue as everyone else. So I pulled out my carpet completely today to get to the problem. I pulled the plastic cover under all the caps off as well to see if there was a fluid coming out of a potentially faulty cap. My tank appears brand new as do my hoses and the cap did not appear to be the issue since there wasn't any fluid up top. It was all spotless.
Now what i did find is a small leak from directly under the tank where a small hose goes into a rubber gasket into the body of the car. Can anyone tell me what this hose is for, where it goes, and a possible solution? Any help will be very appreciated.
RENNX is offline   Reply With Quote
