Originally Posted by Frodo
(Stupid question...) That would imply a sound coming from the rear of the car, right? Although I know it's possible to get fooled on locating weird sounds, this really sounds like it's coming from the front, specifically the passenger side.
In any case, having discovered that 3 of 4 axle boots were torn, I had the axles repacked and new boots put on just over a year ago. I haven't looked at them recently but it seems unlikely they should be a problem already.
It was just a thought. Based on what you described, it sounded characteristic of a bad cv joint. Sometimes a noise can sound like its coming from one area, when in actuality its originating from another. In any case, I trust your judgement .
JD
p.s. A remote possibility could be a tire that isn't properly "seated". I've seen in the past, tires that were poorly mounted, resulted in a similar strange noise, whereby the sound also increased and decreased with acceleration. Again, just another thought.
